Point Hotspot can´t be moved   [SOLVED] - View the solution
rruiz
Liked in: 5 posts
by rruiz » Mon May 12, 2014 12:51 am
Windows 7
Panotour 2.1
I can´t move a hotspot created; if I clic and try to drop doesn´t move always... in most of the cases don´t. It´s horrible because if a hotspot is not localed in the correct place, I need to delete and create anew one instead of trying to move the current spot. (For your info) I can select it and turns "blue"
Why?
Roberto
Likes: 13 posts
Liked in: 118 posts
Re: Point Hotspot can´t be moved
by bdd » Tue May 13, 2014 8:46 am
rruiz wrote:Windows 7
Panotour 2.1
Why?
Roberto
You cannot move a spot created automatically on the GPS coordinates of a panorama.
But you can change the GPS coordinates of this panorama. There you can move the marker to set the correct coordinates.
http://www.autopano.net/wiki-en/action/ ... CALISATION
by mediavets » Tue May 13, 2014 9:30 am
Panotour 2.1
Why?
Roberto
I could not move a normal Point hotspot.
PTP 2.1 64-bits on Windows 8.1 pro.
rruiz
Liked in: 5 posts
by rruiz » Tue May 13, 2014 10:20 pm
mediavets wrote:
Panotour 2.1
Why?
Roberto
Yes... I think it is a bug because as he said happened with a normal hotspot, not a GPS hotspot !
Likes: 13 posts
Liked in: 118 posts
by bdd » Wed May 14, 2014 11:55 am
rruiz wrote:
mediavets wrote:I could not move a normal Point hotspot.
To move a spot, you have to select the icon correponding to the spot type.
If you selected the "move" icon, you can move the panorama, not the spot.
The hotspot editor did not change between the 1.8 version and this one. This behaviour is the same as before.
by mediavets » Wed May 14, 2014 12:06 pm
I guess I'd forgotten how to do it.
I tried using the Select icon to select the hotspot I wished to move by dragging it after selecting.
That seems an intuitive approach
Note it's named 'Select' not 'Move'.
The method that works seems quite counter-intuitive to me.
rruiz
Liked in: 5 posts
Re: Point Hotspot can´t be moved  [SOLVED]
by rruiz » Sat May 17, 2014 11:52 am
Guys thanks.
We have to move within the hotspot editor and not with the select tool. Thanks for the clarification.
Regards
Liked in: 227 posts
by Destiny » Sat May 17, 2014 12:33 pm
Any of the features in the Spot Editor can be edited after placement, as long as you select the relevant feature first.. So if you need to move a hotspot, you first select the hotspot.. Then you can drag it or right mouse to remove.. If you need to move the points on the Polygon, you first select the Polygon then you can move the node on the Polygon.. Same with the other features, Picture, Video and Sound....
by mediavets » Sat May 17, 2014 12:51 pm
Destiny wrote:Any of the features in the Spot Editor can be edited after placement, as long as you select the relevant feature first.. So if you need to move a hotspot, you first select the hotspot.. Then you can drag it or right mouse to remove.. If you need to move the points on the Polygon, you first select the Polygon then you can move the node on the Polygon.. Same with the other features, Picture, Video and Sound....
Yes, so what's the point of the Select icon?
Liked in: 227 posts
by Destiny » Sat May 17, 2014 1:15 pm
Thats to side the entire pano left to right to change the position.. In case you might want to draw a polygon, picture or video that goes over the ends...
by mediavets » Sat May 17, 2014 1:23 pm
Destiny wrote:Thats to side the entire pano left to right to change the position.. In case you might want to draw a polygon, picture or video that goes over the ends...
Should in be named something other than 'Select' then?
You can use it to select a hotspot but having selected the hotspot you cannot drag it...that's counter-intuitive (for me anyway).
Liked in: 227 posts
by Destiny » Sat May 17, 2014 2:13 pm
Emm... Never thought about it.. If a TV was half on the right and half on the left, I have just dragged it over, drawn the polygon then dragged it back.. Really hang tool.. Perhaps call it the Pan tool.
