Fly-out / pop-up photo distortion / PTP 1.8
tarheel360vr
by tarheel360vr » Fri Apr 04, 2014 3:22 pm
Most fly-out images I set up display at the correct proportions. I use the percentage option (60% x 60% usually). But some images appear distorted (as if 60% x 40%, for instance).
Attached examples show one right, one wrong.
Any tips on how to prevent or correct this?
Many thanks.
This one displays at correct proportions.
Wrong proportions.
Re: Fly-out / pop-up photo distortion / PTP 1.8
by mediavets » Fri Apr 04, 2014 5:22 pm
tarheel360vr wrote:Most fly-out images I set up display at the correct proportions. I use the percentage option (60% x 60% usually). But some images appear distorted (as if 60% x 40%, for instance).
Many thanks.
If your fly-out image dimensions are defined a percentage of the display size then you can never be certain that the aspect ratio will stay the same?
tarheel360vr
by tarheel360vr » Fri Apr 04, 2014 5:33 pm
Choosing percentage display makes more sense to me. If I use pixel dimensions:
• I have to calculate the exact size to avoid distortions. Correct?
• It seems that pixel dimensions would not account for differences in monitor sizes; in other words, what looks "right size" on a 13-inch laptop might look small on a 27-inch display. Or this assumption incorrect?
Thanks very much for the guidance.
by mediavets » Fri Apr 04, 2014 5:38 pm
tarheel360vr wrote:Choosing percentage display makes more sense to me. If I use pixel dimensions:
Correct.
Correct.
OTOH the image would never be distorted; nor pixellated on a very high res. display.
