Tour loads too slowly
Dizzy View
by Dizzy View » Mon Mar 31, 2014 11:38 am
I have created several virtual tours for a client in Panotour 1.8 and they load fine if viewed on an iPad but extremely slowly if viewed in a web browser on Mac or PC. There are only 5 panoramas in the tour, plus floor plan navigation but it takes over 3 minutes to load no matter how fast the internet connection is.
Here is a link to the tour: http://www.arv.org.au/virtual-tours/ebbs-lane/
They were created with Mobile devices Tour selected but Standard Tour wasn't. Should I be checking both boxes? Should I advise my client to link the HTML5 and Flash versions for faster loading?
I had Partial Panorama Width at 2500
Cutting Size 1024
Max Preview Size 800
Jpeg Quality 9
Auto Rotation Delay 1 second
Speed 2
I really can't work out why its taking so long to load. Any ideas would be greatly appreciated.
Thanks!
Re: Tour loads too slowly
by mediavets » Mon Mar 31, 2014 12:06 pm
Dizzy View wrote:I have created several virtual tours for a client in Panotour 1.8 and they load fine if viewed on an iPad but extremely slowly if viewed in a web browser on Mac or PC. There are only 5 panoramas in the tour, plus floor plan navigation but it takes over 3 minutes to load no matter how fast the internet connection is.
The tour loads quite quickly for me here in the UK on a relatively low bandwidth ADSL Net connection (about 2Mbps). A Flash version of the tour is displayed when I view with Firefox 27.0.1 on Windows 7 Pro 64-bit.
When do you consider loading to be 'done' when measuring load time?
Yes. Check both boxes.
What do you mean?
If you select one of the HTML template options and access the tour via that HTML file then a script is invoked to determine which version of the tour should be loaded depending on the detected browser user-agent.
