Virtual Tour does not work on Android Chrome browser
VRspace4
by VRspace4 » Sat Oct 05, 2013 7:35 am
I've built a tour using PanoTour v1.8.0 with the Mobile devices Tour option checked. I've confirmed that it works on the iPhone Chrome browser but not the Android Chrome browser.
The page says
ERROR:
Adobe Flash Player 9/10 or higher needed...
Any work arounds for this? Thanks in advance.
Likes: 3 posts
Liked in: 215 posts
Re: Virtual Tour does not work on Android Chrome browser
by Destiny » Sat Oct 05, 2013 8:12 am
Hi.. Thats due to Adobe stopping support for Flash for Androids, some time now.. This has been a big issue.. Flash on an Android will only work up to 4.1 I think.. After that, it won't.. You need PTP V2 where it builds your Tour using HTML5, and it works wonderfully on my Samsung Note with the latest Android version..... If you are using the latest Chrome, then I would assume you have the latest Android version.. That's your problem.....
VRspace4 wrote:I've built a tour using PanoTour v1.8.0 with the Mobile devices Tour option checked. I've confirmed that it works on the iPhone Chrome browser but not the Android Chrome browser.
The page says
ERROR:
osmica
by osmica » Sat Nov 09, 2013 8:33 pm
I've created my tours for iPhone but it doesn't work on iPhone. It gives me message:
"iPhone / iPad version not available"
What I did wrong? It needs to work created with PTP 1.8.
You can try to view any tour on my site http://www.8realestate.eu
It will automaticly turn it to the mobile version http://www.m.8realestate.eu
Here is an example: http://www.8realestate.eu/en/stanovi-u-istri/u-maloj-zgradi/fashionably-designed-interior-sale-used-one-bedroom-standard-apartment-fully-furnished-croatia-istria-pula-valdebek-usual-view-3-km-to-the-beach-39.05-sqm-172.html
I don't know what can be the reason why it doesn't work on iPhone but can suppose could be only this:
1) I have created the tours in a wrong way.
2) There is needed a different code to view on mobile version for iPhones.
3) Some settings on the iPhone I used are not set well.
Please, can you tell me anything smart to fix my problem? I have use PTP 1.8 settings you can see in the screenshot.
Best regards
Toni
