Using the MAP feature generates a KRpano error
wkaemena
by wkaemena » Wed Aug 28, 2013 5:20 pm
Recently I get always a KRpano error when using the Map feature with hot spots in PTP 1.8 in the HTML Flash version. When transforming the web tour in a standalone Flashplayer tour ( with KR protect Tool), the error will not occur
http://www.kaemena360.net/Forenfotos/Map-error.jpg
by mediavets » Wed Aug 28, 2013 7:23 pm
wkaemena wrote:Recently I get always a KRpano error when using the Map feature with hot spots in PTP 1.8 in the HTML Flash version. When transforming the web tour in a standalone Flashplayer tour ( with KR protect Tool), the error will not occur
Are you using one of the 'Zoom...' transitions from the Map hotspots?
I seem to recall that this can cause those sort of errors.
wkaemena
by wkaemena » Wed Aug 28, 2013 9:07 pm
Thanks a lot. Problem resolved !!
