HTML5 Everywhere
gsf
HTML5 Everywhere
by gsf » Wed Aug 28, 2013 3:19 pm
Couldn't find an answer but may not have been patient enough...
If I want to default to HTML5 everywhere it looks like I need to either upgrade to PTP 2.0 and/or get the HTML 5 add on license from KRPano, no?
Currently using PTP 1.8.0 64bit on a Mac and tours default to flash on the desktop. Would like to default to HTML5.
Any help greatly appreciated?
gsf
Liked in: 227 posts
by Destiny » Thu Aug 29, 2013 8:46 am
Hi.. You need to update to PTP V2...
After you create your html file, use the suffix ?html5=prefer or ?html5=always
This way you will have html5 as your default viewing option...
by mediavets » Thu Aug 29, 2013 9:28 am
gsf wrote:Couldn't find an answer but may not have been patient enough...
gsf
As Destiny says you need to upgrade to PTP 2.x - getting the HTML 5 add-on license from krpano is not a solution for PTP 1.8 which already incorporates such a license.
The issue is that PTP 1.8 incorporates krpano V1.0.8.14 - and supports HTML5 exclusively for iDevices - and PTP2.x works with the latest version of krpano (currently V1.16.6) which has much wider HTML5 support.
You should be ware that HTML5 support still varies depending on platform and browser capabilities, see:
http://krpano.com/docu/html5/
PTP 2.x is currently in Alpha 16 state - incomplete with some bugs.
If you wish to upgrade you can do so via your Kolor account. Then use the contact form to ask Kolor to register you on the Kolor VIProom forum set up to support pre-release testing and use of PTP2.x where you will find download links and can obtain peer support with developer input.
http://www.kolor.com/contact.html
gsf
by gsf » Thu Aug 29, 2013 12:19 pm
Thanks Andrew,
We solved the problem by exporting the licenses from PTP 1.8 then used them with the latest krpano protect too - seems to be workingl. We're testing now but, since this is for a closed demo, we should be able to work around any browser problems. Hopefully PTP 2.0 and our release schedule will align in the not to distant future.
Gordon
itsrichphoto
Likes: 8 posts
Liked in: 5 posts
by itsrichphoto » Thu Sep 05, 2013 6:42 pm
ACTUALLY.... with krpano, there is an update tool that updates the swf and .js files to the latest version you have installed on your computer. So you wont have to wait until the latest release which I doubt will actually be any better...
Richard Hart
Commercial and portrait photographer OC California
http://www.richhartphoto.com
