MAP on Panotour
prasad_peiris@yahoo.com
MAP on Panotour
by prasad_peiris@yahoo.com » Thu Aug 01, 2013 10:53 am
We use MAP feature in Project Properties > Extra to use the base for our panorama's. We have two issues with this.
(1) Along with MAP first panorama and it's sounds get loaded. Is there way to avoid loading first pano and its background sounds?
(2) When the MPS is displayed if we click any other area other than hots spots first default pano get loaded. How to disable loading any pano when click non hots pot areas?
Thanks.
Last edited by prasad_peiris@yahoo.com on Thu Aug 01, 2013 10:54 am, edited 1 time in total.
by mediavets » Thu Aug 01, 2013 12:18 pm
prasad_peiris@yahoo.com wrote:We use MAP feature in Project Properties > Extra to use the base for our panorama's. We have two issues with this.
So what would you have load in the background behind the Map graphic? Or would you wish the Map graphic to completely fill the tour display area?
by mediavets » Thu Aug 01, 2013 1:09 pm
prasad_peiris@yahoo.com wrote:(2) When the MPS is displayed if we click any other area other than hots spots first default pano get loaded. How to disable loading any pano when click non hots pot areas?
Thanks.
I cannot replicate that behaviour - do you have an example online?
Which version of Panotour/Panotour Pro are you using?
On which operating system?
What browser are you using to view the tour?
by prasad_peiris@yahoo.com » Fri Aug 02, 2013 6:18 am
We wish the Map graphic to completely fill the tour display area.Have a look on this tour http://www.thegalleryvizu.com/panorama/location1/
if we had a background sound on the pano while the map is displayed that would also have been running.
by prasad_peiris@yahoo.com » Fri Aug 02, 2013 6:21 am
Thanks.
1. here is a on-line example http://www.thegalleryvizu.com/panorama/location1/
2. Version: Panotour Pro Version 1.8 purchased within a month we use it on Windows 64bit
3. We want this to be compatible on ost of the browsers including Chrome, Mozilla, Safari etc.
by mediavets » Fri Aug 02, 2013 8:50 am
OK...it's unusual to have the Map graphic cover the entire tour display area, and I don't see that it adds anything to the tour like that, but if that what you want so be it...
There is no way - from the PTP GUI - to not have the initial pano scene and background sound (if set) load when the map is initially displayed. There may be some way to hand code this, but I'd advise you to avoid that approach as PTP 2.x is already in Alpha release and hasa completely different coding structure so your efforts would not easily transfer to the next version of PTP.
If you used transparency in your map graphic , the PNG format supports transparency, for example where the sea is now - then having it overlaid (at less than 100% of the tour display area) on the initial pano scene with sound on load would seem 'rational' to me and might make more sense to those viewing the tour as well.
by mediavets » Fri Aug 02, 2013 8:54 am
Thanks.
I believe that your report is incorrect.
When clicking anywhere other than a hotspot on the Map graphic, the Map graphic goes to its closed size/position and the current pano/scene continues to be displayed - it does not change to the initial/default pano scene in the tour.
Checked with Firefox, Chrome, Internet Explorer and Safari on Windows XP/32.
