Is there a way to create an html link to a specific panorama ?
seanji
by seanji » Sat Jul 13, 2013 1:33 am
I was wondering if there is a way to create an html link to a specific panorama in a virtual tour. My tour has 12 panoramas and I'd like to be able to open a specific panoramas (virtualtour0, virtualtour1 etc) from a webpage. Does anyone know whether this is possible, and perhaps give me some pointer about how to do it. Thanks.
by mediavets » Sat Jul 13, 2013 9:16 am
seanji wrote:I was wondering if there is a way to create an html link to a specific panorama in a virtual tour. My tour has 12 panoramas and I'd like to be able to open a specific panoramas (virtualtour0, virtualtour1 etc) from a webpage. Does anyone know whether this is possible, and perhaps give me some pointer about how to do it. Thanks.
There is/will be in PTP 2.x, although it's still a bit awkward in PTP 2.x alpha 11.
You can get an upgrade license key for PTP 2.x now if you wish, and use it for production work, although it is still incomplete and not without some bugs.
The alternative solution for PTP 1.8, that I'm aware of, is this commercial plug-in:
http://krpano.com/plugins/userplugins/swfaddress/#top
seanji
by seanji » Tue Jul 16, 2013 4:05 am
Hi Andrew,
Thanks very much for your response. I think I'll go with the PTP 2.x upgrade for my current project. Is there a list of the new features anywhere? Thanks.
seanji
by seanji » Sat Jul 20, 2013 7:22 pm
I have just purchased a license for ptp 2.0 and would like to download and test the current version. Can anyone tell me exactly how I can go about doing this? My OS is Windows 64bit. Thanks.
seanji
by seanji » Tue Jul 23, 2013 1:33 pm
Thanks, I've got it now.
