IPAD/IPHONE TOUR PROBLEMS
gokhankirca
by gokhankirca » Thu Jul 04, 2013 10:14 pm
Virtual tour of this tutorial was a big project for me. Panorama consists of about 80 pieces, but the Ipad, Iphone does not work. For this reason, I am having trouble client at. Krpano do not know how or do not have any experience in XML.
Panotour Pro 2 panotour pro 1.8 alpha release was also lowered, but the whole project. Interfering with the whole thing when you open the file Panotour Pro 2. Support for this project that is also used sketch maps support the drop-down at the bottom left panotour pro 2 version is not available yet.
1.8 Panotour pro tour may choose to build a mobile tour (iPad / iPhone) but I can not select the option.
For now, the biggest problem can be viewed on the computer to view the virtual tour ipad. How can this issue Companion.
Virtual Tour Link
http://uniaday.atilim.edu.tr/atilim-sanal-tur/?id=atilim-sanal-tur
HansKeesom
by HansKeesom » Thu Jul 04, 2013 10:38 pm
Are all panoramas totally 360*180 degrees?
Regards, Hans Keesom
gokhankirca
by gokhankirca » Fri Jul 05, 2013 7:16 am
yes
by mediavets » Fri Jul 05, 2013 11:44 am
gokhankirca wrote:yes
If all panos are 360x180 then I can't see a reason why PTP 1.8 won't allow you to slect the iDevices build option.
You could try doing an Extended save as... under a different project name. Then load that new project and see whether you now have the iDevices build option available.
Beyond that perhaps uninstall PTP 2.x alpha.
Beyond that uninstall and reinstall PTP 1.8.
onuncukoy
Likes: 4 posts
by onuncukoy » Fri Jul 05, 2013 4:27 pm
Good Job Gà¶khan. Kutlarım. BaÅŸarılı çalışmalarının devamını dilerim.
Onuncu Kà¶y Musa
onuncukoy
Likes: 4 posts
by onuncukoy » Fri Jul 05, 2013 4:28 pm
Have you ever been in Izmir, Tower Clock?
http://www.onuncukoy.tv/360videos/saat_kulesi.htm
