From Windows to Mac?
Baldev
by Baldev » Tue Jul 02, 2013 10:19 pm
HI
I created quite a big tour with about 15 panoramas. Now I have to work on it in another office where they have only macs.
So can I somehow export from my Autopano Giga for windows to Autopano pro for mac ??? Or do I have to do the whole tour again on the "Mac Software" ???
THanks already
by klausesser » Tue Jul 02, 2013 10:36 pm
Baldev wrote:HI
THanks already
Yes. You can edit tours made with PTP on Macs in PTP on PCs and vice versa. Take care using the same version of the application . . ;-)
Baldev
by Baldev » Wed Jul 03, 2013 12:58 pm
Hi
But I used Autopano Giga(windows) before and in the other place they have only autopano pro(mac). Does this work?
by AlexandreJ » Wed Jul 03, 2013 3:06 pm
All our software exists in all versions for all platforms. Just use your windows key on the mac version and it will work.
Baldev
by Baldev » Wed Jul 03, 2013 7:11 pm
Jeah ok. But I cant open the panotour file, which I created on the windows computer, on the mac computer. Or maybe Im just to stupid, because I never worked really with mac?! So is this possible?
And as I understand has the key nothing to do with mac or windows? Right?
by gkaefer » Wed Jul 03, 2013 9:48 pm
Baldev wrote:Jeah ok. But I cant open the panotour file, which I created on the windows computer, on the mac computer. Or maybe Im just to stupid, because I never worked really with mac?! So is this possible?
yes & no.
yes... you can use your license bought for Windows on a mac too. install the binary from downlaod section and than use your key.
no... if you wanna open a Project created on one platform on the other one you've to take care on all paths of your drives and Folders used on both platforms.
Windows paths are like C:\foldername\subfoldername\myhtml.html on macs it is rather than working with Linux like /users/myuser/myfolder/mysubolder/myhtml.html...
so jsut open your saved Project file (ist plain XML you can open with any Texteditor capable to open ASCII text....) and adopt the paths...
