Warnings, if the panotour startet from dvd-rom
mwirth
by mwirth » Wed Jun 05, 2013 10:46 am
Hi
I have a strange error in a Panotour 1.8 project (only on Macs):
If the project is online - everything is ok. If the project runs from a CD-ROM - everything ist ok. But if i put the same Panotour on a DVD-ROM, then i got a errormessage (see image) . And only on Macs, on Win-PC's it works fine.
I compared the data on the pc and on the DVD - no difference. Even when i copy the DVD to the harddisk i have the same problem.
Has anyone a clue, whats going on here?
Michael
by mediavets » Wed Jun 05, 2013 11:40 am
May be related to the folder names.
Try getting rid of mixed case, spaces, and 'odd' characters such as & and '.
You also need to set the Flash security settings correctly:
http://krpano.com/docu/localusage/#top
mwirth
by mwirth » Wed Jun 05, 2013 12:16 pm
Thanks.
I have set the Flash-properties. So, the warning about "not local trusted" is gone. But everything else is the same.
I wonder, why this warning appears only from the DVD but not from CD.
First i try now to change the characters.
Michael
mwirth
by mwirth » Wed Jun 05, 2013 7:15 pm
Problem solved.
The key was the name of of the dvd-rom. Even the warning about "not local trusted" is disappeared.
Thanks again to mediavets
Michael
