Error loading video online
Mas
by Mas » Sat Jun 01, 2013 8:59 pm
I have a virtual tour with a m4v video file as a rectangle hotspot (displayed as an object, not as a link).
I can see the tour with the video locally,
I can see the tour without the video on my web server, and i get an error massage that sais: "unable to open video - xxxdata/graphics/spots/spot0.m4v (see image)
The m4v file is 16MB
What should i do? any ideas?
Thank you all!
by mediavets » Sat Jun 01, 2013 9:36 pm
Did the video file get uploaded to the web server?
If it did, check the file permissions.
Mas
by Mas » Sat Jun 01, 2013 9:50 pm
mediavets wrote:Did the video file get uploaded to the web server?
Yes, the file is there..i can't check the permissions though :rolleyes:
by mediavets » Sun Jun 02, 2013 7:47 am
Why not?
Which FTP program did you ue to upload the tour files?
Mas
by Mas » Sun Jun 02, 2013 7:55 am
Why not?
Its complicated :/
I didn't use a program to upload the files..just windows explorer (copy-paste)
rubenscardia
by rubenscardia » Mon Jun 24, 2013 12:50 am
Hi, I've the same problem. I read this post and I checked if the video was uploaded to server and yes, the video is there... then I tried to check the permissions in my server, I checked all positions - write, read and execute... and the problem still occurs! I just can't uderstand and I need help. I usually use the filezilla to upload my files to server.
by mediavets » Mon Jun 24, 2013 8:02 am
rubenscardia wrote:Hi, I've the same problem. I read this post and I checked if the video was uploaded to server and yes, the video is there... then I tried to check the permissions in my server, I checked all positions - write, read and execute... and the problem still occurs! I just can't uderstand and I need help. I usually use the filezilla to upload my files to server.
What is the URL for your online tour?
rubenscardia
by rubenscardia » Tue Jun 25, 2013 3:42 pm
Hi, Mediavets, thanks for your help.
The URL for my tour is: www.rubenscardia.com.br/wp-content/uploads/tour/moradas/tour.html
by mediavets » Tue Jun 25, 2013 5:21 pm
rubenscardia wrote:Hi, Mediavets, thanks for your help.
If the video file is present then why can't I view it at this URL?:
http://www.rubenscardia.com.br/wp-content/uploads/tour/moradas/tourdata/spots/spot3.mp4
I see this is WordPress site - did you use Panopress to install the tour?
rubenscardia
by rubenscardia » Tue Jun 25, 2013 7:24 pm
Sorry, I just can't understand, because I'd checked my server and the video is there.
Well, I recocnize myself as begginer and I can't find a good tutorial about video embede in virtual tour. So What I did was: I'd created a retangle hotspot in the television in the panorama and I'd uploaded all files (including the video at spots file at graphics file at tourdata files? Did I something wrong? Did I miss something?
And yes, my site is a wordpress template with Panopress plugin installed.
