error loading psb
esete
error loading psb
by esete » Mon Apr 29, 2013 12:10 pm
Hello, I'm new and I've stuck in the work process.
I created panorama with AutoPanoGiga and Panotour've loaded it ok.
After I have processed in photoshop and then i can´t load in Panotour.
What is wrong in the process?
Thanks for the help.
garriga - esete
Christian Stüben
Likes: 3 posts
Liked in: 8 posts
by Christian Stüben » Thu May 09, 2013 1:35 pm
some wild guesses...
- did you change file name or file type?
- did you save in ps with a compression ptp doesn´t know?
- is it a spherical pano, and after processing the pixel ratio has changed? (shpericals must have a strict ratio 2:1)
greetings from germny
Chris
