sound dose't work !!!!
delfiol
by delfiol » Thu Apr 11, 2013 9:19 pm
:( someone could help me. I could not put mp3 on my tour !!Does anyone know why????
delfiol
by delfiol » Thu Apr 11, 2013 9:25 pm
I use windows 7 utimate 64-bit service pack 1
delfiol
by delfiol » Thu Apr 11, 2013 9:28 pm
by the way!!! I tried to put the mp3 on a single image !!!! gave me another error!!!!!
by mediavets » Thu Apr 11, 2013 10:48 pm
Welcome to the fourm...
Did you upload the MP3 file?
Is it on your server at that location?
Audio and video files are never embedded in the SWF file.
To be certain that you upload all the files that comprise a tour, build the tour into a new folder using the Build as... option then upload everything in that folder maintaining the file and folder structure.
delfiol
by delfiol » Thu Apr 11, 2013 10:52 pm
yes!! that all there!!!
delfiol
by delfiol » Thu Apr 11, 2013 10:56 pm
I saw something new here!!. what is this soundinterface.swf ???
delfiol
by delfiol » Thu Apr 11, 2013 10:59 pm
by the way!!! It dosen't work on the web!! on my computer it's work!!
by mediavets » Thu Apr 11, 2013 11:01 pm
delfiol wrote:yes!! that all there!!!
So why do I get a 404 when I try to access the URL mentioned in the error message:
www.all360.com.br/360/capital_4/capitaldata/sounds/sound0.mp3
delfiol
by delfiol » Thu Apr 11, 2013 11:07 pm
no!!! I gave you a exemple!! if you want to see!! see thes!!!
http://www.all360.com.br/360/dd/dd.html
by mediavets » Thu Apr 11, 2013 11:11 pm
delfiol wrote:no!!! I gave you a exemple!!
Which doesn't exist on the server!
What was the point of that? :rolleyes:
Is there a problem with this tour?
I can hear the sound and there are no error messages.
delfiol
by delfiol » Thu Apr 11, 2013 11:13 pm
this is ok
delfiol
by delfiol » Thu Apr 11, 2013 11:17 pm
I'm desperately trying all day and I'm doing several tests.
  For that reason they have other name
by mediavets » Thu Apr 11, 2013 11:19 pm
I don't understand what your problem is anymore.
You said 'sound doesn't work' but you sent me the URL to a tour where the sound is working perfectly well:
So do you still have a problem?
If so what is it?
delfiol
by delfiol » Thu Apr 11, 2013 11:23 pm
delfiol
by delfiol » Thu Apr 11, 2013 11:28 pm
Are you serious??
by mediavets » Thu Apr 11, 2013 11:28 pm
delfiol wrote:I made a new tour!!
http://www.all360.com.br/360/ff/ff.html
And....what?
This tour is working fine including the sound - some sort of rock music.
http://www.all360.com.br/360/ff/ffdata/sounds/sound0.mp3
Do you think you still have problem with sound in tours?
If so, maybe you have suddenly gone deaf ? ;)
delfiol
by delfiol » Thu Apr 11, 2013 11:36 pm
and blind!! because I keep seeing missing sound!!=|
by mediavets » Thu Apr 11, 2013 11:46 pm
delfiol wrote:and blind!! because I keep seeing missing sound!!=|
At this URL?
If so clear your browser cache.
I viewed your tour with Firefox 20 running on Windows XP Pro 32-bit.
This is the sound I heard, and then downloaded, that is part of your tour -
Here being played in RealPlayer - check out the title, I expect you'll recognise it although it means nothing to me:
by mediavets » Thu Apr 11, 2013 11:49 pm
No error messages for me:
ATXcloud
by ATXcloud » Fri Apr 12, 2013 2:03 am
I'll back mediavets on this. I'm hearing music in both tours.
Rock on, from Austin Tx.
Howdy from Deep in the Heart of Texas!
beacon44
by beacon44 » Mon Apr 29, 2013 7:41 am
I was also found the error message on this forum.. Now resolved the issue.
