Loading Error (IO Error)
Octavias
by Octavias » Fri Mar 08, 2013 6:46 am
Hey Gang. So I am pretty much down with the the project update.
It works great offline, everything is functional and everything works.
BUT when I upload it to my FTP and test it out ONLINE, it gives me a "Loading Error (IO Error)" when loading one of my Panoramas where a specific HTML file is. I have attached the screen shot so this can be observed my closely. Previously, about an hour ago, i had the SAME issue, but it was with a different HTML file in the same project. its weird as hell because i didn't change anything I simply just re uploaded them. I have never had this problem before and i do not know whats causing it.
please help I need to turn this project in Soon!!!
P.S. here is the project link : http://www.acmbphotography.com/Ruskniga/build/Saint-Petersburg.html
It happens when i try to go to "Talking Books and Sheet Music" Panorama.
Thanks for all your help guys!
-Max
"The whole point of taking pictures is so that you don’t have to explain things with words."
http://www.acmbphotography.com/ - website
https://www.facebook.com/ACMBPhotography - facebook
https://www.facebook.com/MaxBolotovPhotography
Likes: 14 posts
by bdd » Fri Mar 08, 2013 7:29 am
I got a "404" error when trying to display the wanted page : http://www.acmbphotography.com/Ruskniga/build/musbooks.html
Is this file uploaded on your server ?
by mediavets » Fri Mar 08, 2013 10:06 am
bdd wrote:Hello,
Me too:
by mediavets » Fri Mar 08, 2013 10:13 am
OK this time I got to view the tour.
Your problems is that you have capitalised the filename - see screenshot 2.
But the filename is not capitalised in the link - screenshot 1.
Always avoid mixed case in directory and filenames; stick to lower case to avoid problems.
Windows is not case senstive but all *nix dervied operating systems are case sensitive.
Octavias
by Octavias » Fri Mar 08, 2013 6:36 pm
Ahh! thanks guys! Ok i am gonna try to export it again when i get to the office and let you know if it works.
Thanks!
-Max
Octavias
by Octavias » Sat Mar 09, 2013 7:02 pm
Hey guys, so i fixed the problem by renaming all of the HTMLs with small letters. Check it out:
http://www.acmbphotography.com/Ruskniga/build/virtualtour.html
I do also have another questions, my stats for each panorama are:
Cube Face Size: 1400
Cutting Size: 641,516 and other numbers. ( Should they be the same for each Panorama?)
Max Preview: 800
Jpeg Quality: 7
I feel like i have been cutting down the quality and its still loads very slow. I want to to work smoothly and fast. Any suggestions?
Thanks in advance!
-Max
by mediavets » Sat Mar 09, 2013 7:30 pm
Octavias wrote:I feel like i have been cutting down the quality and its still loads very slow. I want to to work smoothly and fast. Any suggestions?
Thanks in advance!
-Max
What is the typical bandwith of Internet connection used by poeple likely to view the tour?
I have only about 1.5 Mbps ADSL and I think the performance is acceptable.
Octavias
by Octavias » Sat Mar 09, 2013 9:43 pm
Well I am running on the same thing and mine take a bit slower to load if i deleted all my Cache.
How can i improve the performance?
