Windows 8 Pro - Metro App IE10 - Shockwave Flash Plugin
by gkaefer » Fri Feb 15, 2013 12:29 am
I recently upgraded to Win8.
example tour I created with ptp1.8 using Flash only Option with the defualt fullpage.html template:
http://www.gigapixel.at/test123/virtualtour.html
IE10 has no Problems to Display the tour in normal Windows mode.
if I Access the Metro tile of IE10 and Access the same link, I get note that Flash Player 9/10 or higher is needed and if clicking the install link I get to Adobe page:
http://helpx.adobe.com/flash-player/kb/flash-player-issues-windows-8.html
I followed each single line in this help page and everything was right in place, I've nothing to Change.
nevertheless no success...
do I miss something?
Liked in: 226 posts
by Destiny » Fri Feb 15, 2013 12:42 am
Georg.. Check to make sure you have not checked your ActiveX, if it is uncheck it..
As I remember, its in options at the top right icon..
by gkaefer » Fri Feb 15, 2013 2:35 am
as I wrote.... I did all Points of the help doc.... also checked the active x - it was not enabled & on genuine IE10 its working without issues.
by mediavets » Fri Feb 15, 2013 10:00 am
by gkaefer » Fri Feb 15, 2013 11:40 am
