32-bit to 64-bit
coolokoy_me
32-bit to 64-bit
by coolokoy_me » Wed Feb 13, 2013 9:03 am
I bought Panotour Pro last two years ago and using a 32-bit PC by that time until now. And company planned to upgrades units to a newer PC units but most of it now are 64-bit.
The question is, can i download the 64-bit version of panotour pro and still use the same license key that i got when i purchased it? or do i need to pay for another license for 64-bit?
by mediavets » Wed Feb 13, 2013 9:49 am
coolokoy_me wrote:The question is, can i download the 64-bit version of panotour pro and still use the same license key that i got when i purchased it?
Yes.
by gkaefer » Wed Feb 13, 2013 1:56 pm
yes... and you also can Change OS: if you used windows you can Change to mac vesion with your license too (and vice versa...)
coolokoy_me
by coolokoy_me » Thu Feb 14, 2013 3:06 pm
Thanks a lot... what a relief..
