"Live" Virtuel tours on webpage
villarosen
by villarosen » Mon Nov 05, 2012 8:53 pm
Hi !
I have been using this code for showing virtuel tours "live" on my page and it works fine.
<object width="100%" height="100%"> <embed src="http://www.nordpro360.dk/Radisson-Aalborg/build.swf" width="100%" height="100%" allowFullScreen="true"> </embed> </object>
As we now it is the flash version, instead i want to use the html version, so i can watch them on any platform "live". What code shall i use ?
I am working in Iweb, and it dosent work, if i just change the swf with html.
Can somebody help me?
by gkaefer » Mon Nov 05, 2012 11:07 pm
using panotour pro 1.8...
export your tour by using The fullpage HTML template in the Projct Properties -> Tour Build register and with enabled Mobile devices Tour.
in result you get an html page with a software switch inside HTML5 for the idevices and flash version for rest.
on krpano side you can use the devices flag to create switches...
http://www.krpano.com/docu/xml/#devices-notes
villarosen
by villarosen » Tue Nov 06, 2012 1:57 pm
Hi Georg
Thanks for your reply. I'am not a code expert, but i will try.
Best regards
Lone
