ERROR: plugin(logo4) loading error: virtualtourdata/graphics/logo4.gif
eacapture
by eacapture » Wed Oct 10, 2012 7:09 pm
Hello, I have this problem lately.
When I view the IPHONE, gives this error.
Can you help me?
Liked in: 227 posts
by Destiny » Thu Oct 11, 2012 3:17 am
Hi... Have you checked to see if your logo4.gif grahic is located in "virtualtourdata/graphics/logo4.gif" folder... It might be as simple as uploaded the missing gif graphic...
You can test to see if it can be found by adding the prefix to the virtualtourdata >>> folder.. Meaning the full url to that gif....If it doesn't open in a brower, then its missing or not placed in the right folder....
eacapture
by eacapture » Thu Oct 11, 2012 3:00 pm
Destiny. Not solved.
LOGO4.GIF is there in the folder virtualtourdata.
I can see the tour in Google Chrome and Internet Explorer, with no problems
Only when I see the Iphone or the Ipad is that this problem appears!
http://www.capturezapp.com.br/360/Porta_Paletes/build/virtualtour.html
Liked in: 227 posts
by Destiny » Thu Oct 11, 2012 9:17 pm
OK.. Very strange... One thing was of concern is how long the logos took to load on my Mac.. but at least they were there.. I am sure that the logo is an feature option in iPhones but not 100% certain.. Also, I am not sure why it is saying it cannot find the plugin.. There is no krpano plugin and ptp, is a generic plugin.. I am sure it should be there as part of the default build..
Anyway.. I can only suggest you try a few things.. One, make sure your file names and file extension are not in upper case.. sometimes that has issues..
Also, there are different versions of gif's, I suggest you borrow a gif from the krpano folder, and test that.. if it works, then your gif format is at fault.. I know of at least 3 different formats of gif.. Also, if its an available option, empty your cache.
eacapture
by eacapture » Mon Oct 22, 2012 6:45 pm
Solved!!
The logo was a file of Corel, which was very large. I just exported the logo smaller. and it worked!
Thank you Destiny for try to help me!!!
