APPPLE MOUNTAIN LION BUGS
mrdantas
by mrdantas » Thu Aug 23, 2012 1:30 pm
Is anyone having trouble building tours on the new apple's mountain lions OS? I keep getting the message "Cannot write into file "/tour0.jpg". Could anybody help me? Thanks!
by klausesser » Thu Aug 23, 2012 1:59 pm
mrdantas wrote:Is anyone having trouble building tours on the new apple's mountain lions OS? I keep getting the message "Cannot write into file "/tour0.jpg". Could anybody help me? Thanks!
Could you provide some more information about what you´re doing which way? Basically there are no issues with PTP and MoutainLion as far as i experienced.
Sounds like a path issue.
Does it say "cannot write file" or "cannot write INTO file xxx"?
Is it an older project? Or did you generate it actually using PTP under ML? Do you use "relative paths"?
mrdantas
by mrdantas » Thu Aug 23, 2012 2:06 pm
it says INTO. its a nem project. What's ML? I don't think I use relative paths, because I don';t know what it is. :)
Hey, thanks for your help Klausesser.
by klausesser » Thu Aug 23, 2012 6:18 pm
mrdantas wrote:it says INTO. its a nem project. What's ML? I don't think I use relative paths, because I don';t know what it is. :)
ML=MountainLion :cool:
"relative paths" you can set when saving a project or a pano.
I don´t believe your issue is related to the OS.
radolum
by radolum » Wed Aug 29, 2012 8:33 pm
I have the same problem. Screiben der Datei "/build0" nicht mà¶glich. ("Cannot write into file "/build0.jpg"). while on snow leopard panotour pro worked fine, since i updated to 10.8 i get the same message. Autopano giga instead seems to work fine. i uninstalled all kolor apps, with all the plists, then i let run onyx, installed autopano and panotour new. still have the same problem .....
mrdantas
by mrdantas » Wed Aug 29, 2012 8:38 pm
see? it's not only me! :)
something changed with no reason...
Could you, klausesser, please address this question to Panotour Pro developers?
thanx!
Best regards!
Marcos.
radolum
by radolum » Wed Aug 29, 2012 9:03 pm
... yuppidoo.. problem solved !!!
open panotour pro --- preferences---performances---temporary folder : erase what is written there. press ok. close panotour pro. open again. go again to--- preferences. press restore defaults . close and restart panotour pro.---- worked for me...
mrdantas
by mrdantas » Wed Aug 29, 2012 9:32 pm
GENIUS radolum!!! Thanx a lot man!!
Worked for me too!! :D
Best regards!
Marcos.
