Load embeded panotour swf into another flash movie
ivanov014
by ivanov014 » Mon Aug 06, 2012 9:41 pm
Hi
how do we load an (embeded) pano virtual tour in another swf flash file.
So far we haven't been able to use any as3 swf loading codes to get this working.
i even tried the following krpano embedding into Flash CS example ..no luck
Do you have any sample fla to provide for that purpose.
var krpano:Object = null;
function krpano_load():void
    var krpanoloader = new Loader();
    krpanoloader.contentLoaderInfo.addEventListener(Event.COMPLETE, krpano_load_complete);
    krpanoloader.load(new URLRequest("myembeded_pano.swf"));
function krpano_load_complete(event:Event):void
    (event.target.content as Object).embeddedstartup(stage, krpano_ready);
// start
krpano_load();
function krpano_ready(krpanointerface:Object):void
    krpano = krpanointerface;
    // open the krpano log and show a message:
    krpano.call("showlog(true);");
    krpano.set("debugmode", true); // show 0/debug traces
    krpano.trace(0,"ready...");
    // load a inline xml with a preview image as demo
    krpano.call("loadxml('<preview type=\"grid(cube);\" />');");
    // example: load a pano xml:
    //krpano.call("loadpano(pano.xml,null,MERGE,BLEND(1));");
    // get notified about krpano resize events
    krpano.set("events.onresize", krpano_resize_event);
    // change the pano area to a fixed size:
    var area:Object = krpano.get("area");
    area.x      = 20;
    area.y      = 20;
    area.width  = 400;
    area.height = 300;
    // examples how to add/change plugins from as3:
    // 1. the "set-interface" way:
    krpano.call("addplugin(button1);");
    krpano.set("plugin[button1].url", "button.jpg");
    krpano.set("plugin[button1].parent", "STAGE");
    krpano.set("plugin[button1].align", "righttop");
    krpano.set("plugin[button1].x", 10);
    krpano.set("plugin[button1].y", 10);
    krpano.set("plugin[button1].onhover", "showtext(toggle pano layer);");
    krpano.set("plugin[button1].onclick", toggle_krpano_visibilty);
    // 2. the direct object way (faster)
    krpano.call("addplugin(button2);");
    var button2:Object = krpano.get("plugin[button2]");
    button2.url     = "button.jpg";
    button2.parent  = "STAGE";
    button2.align   = "righttop";
    button2.x       = 10;
    button2.y       = 50;
    button2.onhover = "showtext(change area size);";
    button2.onclick = toggle_krpano_area;
function krpano_resize_event():void
    krpano.trace(0,"pano resize - pos=" + area.pixelx + "," + area.pixely + " size=" + area.pixelwidth + "x" + area.pixelheight);
function toggle_krpano_visibilty():void
    var imagelayer:Sprite = krpano.get("image.layer");
    if (imagelayer.visible == true)
        imagelayer.visible = false;
    else
        imagelayer.visible = true;
    // toggle also the plugin layer
    krpano.set("plugin.visible", imagelayer.visible);
function toggle_krpano_area():void
    // just toggle between two sizes
    if (area.x == 20)
        area.x      = 0;
        area.y      = 0;
        area.width  = "100%";
        area.height = "100%";
    else
        area.x      = 20;
        area.y      = 20;
        area.width  = 400;
        area.height = 300;
by gkaefer » Mon Aug 06, 2012 9:57 pm
ivanov014
by ivanov014 » Tue Aug 07, 2012 9:38 pm
thx gkaefer, unfortunately this post did help..
i haven't found a proper way to load a a panotour swf into another flash movie..
Would you have any solution for us. ?
