Tours are buggy on Android Tablets ahnd iPads
RickDrew
by RickDrew » Tue Jul 31, 2012 9:58 pm
Beet testing my tours on iPads and Android tablets. Maps and thumbnails don't load on iPads. For droids, gyroscope does not work (Droids DO have them) and the + and - buttons don't work. The other navigation buttons are buggy and only work if you press the help button first. And then it can take several presses.
Any ideas or suggestions?
by mediavets » Tue Jul 31, 2012 10:33 pm
RickDrew wrote:Beet testing my tours on iPads and Android tablets. Maps and thumbnails don't load on iPads.
The Panotour Maps plugin is Flash only in V1.8.
Are yiu using the Thumbnails feature or the Thumbnails stack feature?
Gyroscope plugin is supported by the krpano HTML/javascript Panorama Viewer, for iphone 4 and iPad 2. Android devices use the krpano Flash Panorama Viewer.
