This is getting really, really frustrating. A 50+ image tour. Spent days linking everything, adding descriptive titles, etc. Regenerated, uploaded. Only to find that links and entire images have been replaced. The original file is fne - just the generated files are incorrect. Any suggestions? Tried deleting all the generated files, regenerating, clearing cache. Even tried it on an iPad - gyroscope is great, but the images and links are wrong.
In current version of PTP, the panorama tiles are created under a indexed sub-directory. This index changes if you change the panorama order in PTP. So each time you change the panorama order in PTP, I suggest you to build entirely the tour. If you do not an entire build, then the "first" panorama directory may contain tiles for the "fourth" panorama, etc..
In future version PTP, we will try to create panorama tiles, under clearly indentified sub-directories. This will solve such issue and this will also allow you to do "incremental" builds, even while re-opening an old tour in PTP.
