error when you click on the hotspot map.
AndreyNv
by AndreyNv » Sat Jul 14, 2012 11:50 am
Hello!
I have a problem. error when you click on the hotspot map. Tell me, how can I fix it?
by mediavets » Sat Jul 14, 2012 12:23 pm
Welcome to the forum...
You need to set the Flash security settings appropriately:
http://krpano.com/docu/localusage/
AndreyNv
by AndreyNv » Sat Jul 14, 2012 2:31 pm
Thanks for your advice, but the problem is not solved. An error exists and online http://kvartira360.ru/b168
by mediavets » Sat Jul 14, 2012 2:51 pm
AndreyNv wrote:Thanks for your advice, but the problem is not solved. An error exists and online http://kvartira360.ru/b168
OK - the problem seems to be related to changes made 'under the hood' to pano transitions between PTP 1.7 and 1.8.
See: http://www.kolor.com/forum/t14416-panotour-pro-1.8-problem
You need to open the tour project and change the transition type on the map hotspots.
You should avoid any of the transition types named 'Zoom.......'
Then re-build the tour.
AndreyNv
by AndreyNv » Sat Jul 14, 2012 3:59 pm
Thank you! The problem is solved.
