Just purchased and have '' LICENSE ERROR''
fincafamiliar.com
by fincafamiliar.com » Fri Jun 29, 2012 8:37 pm
mediavets wrote:
mediavets wrote:
fincafamiliar.com wrote:sorry, the link you provided is showing a lot of posts. Should I look into one specificly?
Ooops - sorry, my mistake - here we are:
http://www.kolor.com/forum/t14416-panotour-pro-1.8-problem
I've been experimenting and it is as Gerald described in the psot mentioned above.
The problem arises because you created the tour with 1.7.x and are now working on it with 1.8 where changes were made 'under the hood' relating to transitions behaviours.
You can solve the problem by opening the project again in 1.8 and changing the map hotspot transition type to 'default' for all the map hotspots, the rebuild the tour and the problem will be solved.
Ok, I cheked the post.
Now I will change the transitions to default.
The tour is made in 1.8 from scratch.No 1.7 involment.
I will post a link if it works
fincafamiliar.com
by fincafamiliar.com » Fri Jun 29, 2012 8:52 pm
IT WORKS!!!!
Thank you guys!
http://fincafamiliar.es/benissanet/bnsvirtu/bnsvirtu.html
so only default setting for the transitions in the map.
by mediavets » Fri Jun 29, 2012 9:11 pm
fincafamiliar.com wrote:IT WORKS!!!!
Thank you guys!
I prefer the Thumbnails stack option to the Thumbnails option - try it and see which you prefer.
I haven't tried others yet. Perhaps I'll explore the others later.
For now default is the safe choice.
fincafamiliar.com
by fincafamiliar.com » Fri Jun 29, 2012 10:00 pm
mediavets wrote:I prefer the Thumbnails stack option to the Thumbnails option - try it and see which you prefer.
Thanks for the advice. This forum is great.
by mediavets » Fri Jun 29, 2012 11:27 pm
I did some more testing and it's just the Zoom In and Zoom transitions that don't work for Map hotspots.
Previous
