SWF movie doesnt play
willem
by willem » Wed Jun 27, 2012 12:39 pm
I have a flash movie (.swf file) which works perfectly, except when i put it as a object in the pano, i can see the movie frame 1, but it doesnt autoplay.
What do i need to do to let it autoplay ?
by mediavets » Wed Jun 27, 2012 12:52 pm
willem wrote:I have a flash movie (.swf file) which works perfectly, except when i put it as a object in the pano, i can see the movie frame 1, but it doesnt autoplay.
How are you trying to use this SWF animation - PTP doesn't consider SWF to be a movie/video format - as the Link/Object or as the Display/Object for a hotspot?
If so can you show us a screenshot of the settings?
willem
by willem » Wed Jun 27, 2012 2:13 pm
by mediavets » Wed Jun 27, 2012 2:41 pm
Can I download that SWF file?
willem
by willem » Wed Jun 27, 2012 3:05 pm
yeah ofcourse
i uploaded online
http://www.2shared.com/document/G96_chrW/goofy.html
its a sily movie, but that doesnt matter :)
thnx for helping out
by mediavets » Wed Jun 27, 2012 4:40 pm
willem wrote:yeah ofcourse
i uploaded online
I don't know why the SWF doesn't animate if you use it as the Display/Object for a Rectangular hotspot.
But....it does animate correctly is you use it as the Display/Object for a Point hotspot.
So I guess that's a solution/workaround?
A tip - when specifiying the size you need only enter a value for one dimension, if you leave the other dimension at '0' (zero) then the aspect ratio of the object or image will be maintianed.
by klausesser » Wed Jun 27, 2012 5:10 pm
Hi!
Convert the movie to .flv - that´s the Flash-video format.
P.S.: i saw right now it´s a Flash-animation and not a movie.
