Hotspot url & javascript dont work
willem
by willem » Tue Jun 26, 2012 2:35 pm
Hello people
i have two question reagarding hotspots which i need help with. i hope u guys can help me out
question one:
when i creat a hotspot and go to hotspot properties i set the hotspot to url, type in any url, f.a http://www.google.nl, i rebuild my pano, en when i view the pano, i see the hotspot but when i click it it doenst open the url. it also doesnt matter if i set it to _blank, parent or self, nothing seems to work. It doesnt work in any browser. Anyone have a solution for this ?
second question
second question is regarding javascript.
in virtualtour.html i put a function, say:
function test() { alert("test"); }, and i put test() in the javascript line in the software, why doesnt this work ?
thnx alot for helping out.
by mediavets » Tue Jun 26, 2012 2:39 pm
willem wrote:when i create a hotspot and go to hotspot properties i set the hotspot to url, type in any url, f.a http://www.google.nl, i rebuild my pano, en when i view the pano, i see the hotspot but when i click it it doenst open the url. it also doesnt matter if i set it to _blank, parent or self, nothing seems to work. It doesnt work in any browser. Anyone have a solution for this ?
Is this with local (offline) playback or viewing online?
If local, have you set Flash security settings appropriately?:
http://krpano.com/docu/localusage/
by klausesser » Tue Jun 26, 2012 2:40 pm
willem wrote:when i creat a hotspot and go to hotspot properties i set the hotspot to url, type in any url, f.a http://www.google.nl, i rebuild my pano, en when i view the pano, i see the hotspot but when i click it it doenst open the url. it also doesnt matter if i set it to _blank, parent or self, nothing seems to work. It doesnt work in any browser. Anyone have a solution for this ?
Put it online - and it works . . Doesn´t work locally.
by mediavets » Tue Jun 26, 2012 2:50 pm
klausesser wrote:. . Doesn´t work locally.
It will with appropriate Flash security settings.
willem
by willem » Tue Jun 26, 2012 3:05 pm
okay question 1 (embarressed) works thnx guys !
anyone have a solution for my second problem ?
by mediavets » Tue Jun 26, 2012 4:09 pm
willem wrote:anyone have a solution for my second problem ?
I don't know whether your javascipt syntax is OK nor whether javascript will work locally but I do know that you must enter at least one domain - see screenshot - for javascript to work.
willem
by willem » Wed Jun 27, 2012 12:37 pm
problem fixed, thnx for the help
topic can be closed :)
Revolution
by Revolution » Thu Jul 12, 2012 3:25 am
I'm not sure if this is the a similar issue.
I create a vt.... And Place a hotspot.
Many times, I can see the hotspot but the hotspot is not clickable. No tooltip appears on the hotspot.
If I drag the Pano around a little... Then place the cursor over the hotspot... A tooltip appears and the hotspot becomes clickable.
Any ideas ?
Revolutiion Photography, AP Freelance Photographer
Nikon D3, D3x : Nikkor 16mm f/2.8, 14-24mm f/2.8, 24-70mm f/2.8, 70-200mm VR2 f/2.8, 105mm f/2 DC, 50mm G f/1.4, Nodal Ninja M1-L Ultimate / RD16, Win 7 16GB + Dual 24" Monitors, MacPro 16GB + Dual 36" Cinema Monitors, MacBook Pro 17" 8GB, MacBook Pro 15" 8GB, MacBook Pro 13 4GB, iPad 64GB 3G+Wifi, iPad II 64GB 3G+Wifi
