Fullscreen button doesn't work on iPad or iPhone?
Hewitt
by Hewitt » Tue Jun 05, 2012 11:38 am
The Fullscreen button doesn't work when viewing tours on an iPad or iPhone. Is this a bug... or is there another solution?
Hewitt
Mqriaz1
by Mqriaz1 » Mon Jul 23, 2012 11:06 pm
Im having the same issue. Any update on this?
by mediavets » Mon Jul 23, 2012 11:22 pm
Mqriaz1 wrote:Im having the same issue. Any update on this?
Welcome to the forum...
I think this is probably relevant?:
http://krpano.com/forum/wbb/index.php?page=Thread&threadID=6551
marianne
by marianne » Mon Oct 01, 2012 2:52 pm
Hi there,
I am having the same problem with this tour.
http://www.perthroyalshow.com.au/whats-on/iga-follow-the-yellow-brick-road/Virtual-Tour.aspx
I have check out the links above. From what I understand ( with my lack off geek knowledge) this problem is to do with a Safari issue not supporting fullscreen for HTML5.
So if users were to use another browser perhaps it would work???
Any development or tips to fix this issues since the last posts?
Marianne
