XML parsing failed
Korben5
XML parsing failed
by Korben5 » Mon Jun 04, 2012 4:39 pm
I've searched the forums and haven't found a solution to my problem. I have a registered and licensed version of Panotour Pro (v 1.0.8.14) and I've been experiencing problems viewing my tours via iphone/pad since the last update. Every new tour I create gives the error "Fatal Error: Index.xml - xml parsing failed!". See examples below.
After update, new tours I create do not work properly via iphone/pad:
http://www.gsjackson.com/demo/index.html
Before update, this tour works fine on iphone/pad:
http://www.gsjackson.com/villages/demo.html
Any help to solve this issue would be greatly appreciated.
Thank you
by mediavets » Mon Jun 04, 2012 4:50 pm
Which operating system are you running for PTP?
Korben5
by Korben5 » Mon Jun 04, 2012 4:51 pm
Mac OS X (v 10.6.8)
by klausesser » Mon Jun 04, 2012 5:29 pm
Korben5 wrote:I've searched the forums and haven't found a solution to my problem. I have a registered and licensed version of Panotour Pro (v 1.0.8.14) and I've been experiencing problems viewing my tours via iphone/pad since the last update. Every new tour I create gives the error "Fatal Error: Index.xml - xml parsing failed!". See examples below.
Thank you
Did you update KRPano/KRPano-Tools to resp. have a iPhone/Pad-license?
I suggest to use always the latest KRPano/KRPanotools.
P.A.: might be better to delete all presets of APG/PTP before installing newer versions. (i never had any issues - MacOS10.6.8 - but i read about some).
Korben5
by Korben5 » Mon Jun 04, 2012 6:29 pm
Klaus, not exactly sure what you mean by "update KRPano/KRPano-Tools to resp. have a iPhone/Pad-license". When I build the tour, it automatically includes a krpanoiphone.license.js file. Is that what you mean?
Thanks,
by klausesser » Mon Jun 04, 2012 7:40 pm
Korben5 wrote:Is that what you mean?
Thanks,
Hi!
Yes. Did you run the latest KRPano-update?
*If you kept the structure that PTP builds* i can´t imagine much reasons for this error-message.
Korben5
by Korben5 » Mon Jun 04, 2012 9:23 pm
I noticed a small problem in my XML (an "onclick" and "onhover" command didn't have a space between them) and my tour is trying to load. Problem now is that my iphone keeps getting these error alerts at the bottom of the screen: "Warning: tween type 'quadratic' not found - using 'easeOutQuad' instead!"
Any idea how to fix it? Here's the link again: http://www.gsjackson.com/demo
Korben5
by Korben5 » Mon Jun 04, 2012 9:31 pm
Problem solved. The "spot1.png" image was missing from indexdata/graphics/spots
