Wordpress
George Randy Bass
Wordpress
by George Randy Bass » Fri May 25, 2012 4:33 pm
My websites are developed in Wordpress. I have used Kimili Flash Embed which provides a full Wordpress interface for SWFObjects. Below is the code I am using which is typical for running SWF files.
[kml_flashembed movie="http://virtualpanoramictours.com/wp-content/swf-files/joynerfinal/build/virtualtour.swf" height="400" width="580" /]
ERROR: download of "virtualtourdata/graphics/spots/object2.jpg" failed
ERROR: download of "virtualtourdata/graphics/spots/spot1.png" failed
ERROR: download of "virtualtourdata/graphics/spots/spot2.png" failed
ERROR: download of "virtualtourdata/graphics/spots/spot3.png" failed
ERROR: download of "virtualtourdata/graphics/spots/object4.jpg" failed
ERROR: download of "virtualtourdata/graphics/spots/object5.JPG" failed
ERROR: download of "virtualtourdata/graphics/spots/object6.jpg" failed
ERROR: download of "virtualtourdata/graphics/spots/object7.png" failed
ERROR: download of "virtualtourdata/graphics/spots/object3.jpg" failed
ERROR: download of "virtualtourdata/virtualtour0/0/0_2.jpg" failed
ERROR: download of "virtualtourdata/virtualtour0/0/0_1.jpg" failed
ERROR: download of "virtualtourdata/virtualtour0/0/0_0.jpg" failed
ERROR: download of "virtualtourdata/virtualtour0/0/0_3.jpg" failed
Below is a link to the sample page with errors
http://virtualpanoramictours.com/48-2
Any suggestions on repairing this?
Thanks!
“For the love of photography, the seed of imagination!”
by mediavets » Fri May 25, 2012 4:58 pm
Take a look at PanoPress:
http://www.panopress.org/
George Randy Bass
by George Randy Bass » Fri May 25, 2012 5:18 pm
Beautiful! That worked!
nonchiedercilaparola
by nonchiedercilaparola » Thu Jun 28, 2012 4:32 pm
mediavets wrote:Take a look at PanoPress:
i'm trying to use this plugin in my local installation of wordpress.
in the page "visual" i'm write:
[pano file="VT/Civ_Sam_4Mar12/VT.html"]
in plugin settings my folder path is "wp-content/uploads"
but don't work. is it possible that this plugin don't work in local? i ask in forum support panopress but nothing. does Some one test this plugin in local?
by gkaefer » Fri Jun 29, 2012 1:24 pm
what do you understand with "local"?
1. having the files on a local harddrive located and accessing these with your webbrowser locally?
2. having a apache webserver + php + mysql + wordpress installation locally on your Computer where you've created an "local" webspace for your website you try to add panopress?
ad 1.: cant work - because wordpress depends on a http server, php, mysql and others
ad 2.: does work
PS: your paths you used:
so it should exist wp-content/uploads/VT/Civ_Sam_4Mar12/VT.html
I would rather use in the posting or page:
[pano file="mozartplatz-20110416/mozartplatz-20110416.swf" width="640" height="256" preview="mozartplatz/mozartplatz-preview.jpg"]
and the folders (preview, files and subfolders of the panotour project) are placed under:
wp-content/uploads/mozartsteg-20110507
result: http://www.gigapixel.at/?p=195
by nonchiedercilaparola » Sun Jul 22, 2012 1:30 pm
hi, thanks for the reply. if i link a virtual tour that is online
[pano file="http://www.site.it/file.html"]
the plugin work
if i link a virtual tour that is in a local directory of my wordpress, the plugin don't work.
the [pp] button don't work in all two cases.
however
is there a possibility to set the height and witdh in percentage with pano press? no...:(
http://www.panopress.org/forum/discussion/168/thumbnail-dimensions-as-percentage/p1
so panopress and i[frame] don't work correctly:(
Last edited by nonchiedercilaparola on Sun Jul 22, 2012 1:47 pm, edited 1 time in total.
