Settings for 'Quick Export's filename...
CheeseAndJamSandwich
by CheeseAndJamSandwich » Sun Mar 04, 2012 6:02 pm
Is there, or can there be a way of changing the file name structure of the Quick Export?
At the moment, it prefixes the file name with "tour_"
This means the tour doesn't sit next to the pano image if other files are in the directory, when sorting by name.
It would be better to at least have it suffixed, or even just the same name but with the obvious change in extension.
An option for this would be great, cheers.
Likes: 14 posts
by bdd » Mon Mar 05, 2012 10:54 am
Currently you cannot tune the "Quick export" feature.
I added a "Feature request" to be able to modify its parameters in a future version of PTP.
by CheeseAndJamSandwich » Mon Mar 05, 2012 5:12 pm
bdd wrote:Currently you cannot tune the "Quick export" feature.
Thanks!
