"Max. preview size The preview is a low quality version of the panorama that is viewed when the virtual tour is launched. This version is viewed until the image is completely uploaded. You can adjust the quality here.
Jpeg quality Lets you define the Jpeg quality factor applied to the images when the tour is exported. The bigger it is, the less visible the compression effects are. This will play a role on the weight of the tour."
-> sentence "You can adjust the quality here." seems to be obsolete, since it is appropriate for the JPG Quality adjustment below?
cheers chris
Merlin GoTo w PapyWizard / BT Module (TA) / Touch Control Panel / DP MX2 Dolly Engine, AstroTrac TT320X-AG, Dynamic Perception Stage Zero, Nikon D3s, D700, D7000, Nikkor AF 16/2.8 Fisheye D, Nikkor AFS 14-24/2.8, AFS 24-70/2.8, AFS 80-200/2.8 D ED, AF 50/1.8, AF Micro Nikkor 60/2.8, TC2-EIII, iMac 27" i7, MBP 17" i7, Parallels WinXP, several RAIDs and NAS, cat, dog & fish
dont think so. if you're visiting the tour with a screen with 1600xY pixel. and you've set 800 as preview size than the image has a smaller quality than if you use 1200 as preview size... Georg
