some bugs on 1.7
vertrider
some bugs on 1.7
by vertrider » Sat Nov 26, 2011 8:08 pm
Hi Panotour Team,
two MacbookPro i7, OSX 10.6.8 with the wollowing bug after upgrade to panotour 1.7 (was not there before with 1.6):
- projects I create with 1.7 to test locally, freeze after start, once I klick on the first hotspot in the image (doesn't matter which one of a group)
- when I don't klick on a hotspot but just move around the start panorama it works, until I klick into the first hotspot
- all this does not happen with the same project FTPed to the client
but it makes it impossible to test the project locally.
- I have force deleted all files in that panotour project folder and rebuild
- doesn't matter if I open the project locally on safari or firefox, both flash player freeze
- flash player is v11 (latest update)
if I upload the project to the website, it doesn't freeze. I'd like to send you a link to the project, because it is not public due to the client. I also can send XML files etc.
pls concact me at office(replace)christophmalin.com, as I have some urgent projects, thx
In the meantime I probably go back to 1.6.x?
cheers
chris
Merlin GoTo w PapyWizard / BT Module (TA) / Touch Control Panel / DP MX2 Dolly Engine, AstroTrac TT320X-AG, Dynamic Perception Stage Zero, Nikon D3s, D700, D7000, Nikkor AF 16/2.8 Fisheye D, Nikkor AFS 14-24/2.8, AFS 24-70/2.8, AFS 80-200/2.8 D ED, AF 50/1.8, AF Micro Nikkor 60/2.8, TC2-EIII, iMac 27" i7, MBP 17" i7, Parallels WinXP, several RAIDs and NAS, cat, dog & fish :)
deminggray@gmail.com
by deminggray@gmail.com » Wed Nov 30, 2011 11:49 pm
I just bought panotour pro 1.6 in October. When I started the program tonight a dialogue box informed me of an upgrade to version 1.7 that was available. Do I have to purchase the upgrade? The installation software will not accept my php code for version 1.6
by mediavets » Thu Dec 01, 2011 4:29 am
Welcome to the forum...
deminggray@gmail.com wrote:I just bought panotour pro 1.6 in October. When I started the program tonight a dialogue box informed me of an upgrade to version 1.7 that was available. Do I have to purchase the upgrade?
No.
Are you sure you downlaoded the correct version - did you downlaod Panotour or Panotour Pro?
Likes: 14 posts
by bdd » Thu Dec 01, 2011 8:46 am
Hello Chris,
This post is only a copy of the mail I sent you on monday 28 november.
Yes it would be great if I got an URL pointing to the tour where this bug occurs.
Could you also send me the project file "*.kpt" of this tour ?
Do you still have the*.kpt file created with the 1.7 ?
If you downgraded to the 1.6 version, you probably do not have it anymore, but it would help me if you can re-create this file.
Could you also send me the XML's file of the tour ? If you embed them in the swf file, you will have to re-build the tour after un-checking the checkbox "Embed XML files".
jandunlop
by jandunlop » Mon Dec 05, 2011 7:11 pm
Yep, I can confirm exactly the same problem - pano freezes after clicking on the first hotspot when viewing locally.
does not matter which browser
windows 7 64 bit
Let me know if there is anything else I can provide in terms of files etc....
Edit1: Also this tour was created initially in 1.6 then opened and exported in 1.7
Edit2: Seems to have the same problem when uploaded as well, going to start from scratch and rebuild the whole projest to see if that fixes it
jandunlop
by jandunlop » Mon Dec 05, 2011 10:47 pm
OK, I rebuilt a tour from scratch and still have the same problem. Clicking on any hotspot or panorama thumbnail freezes the whole thing on local.
Flash version 11,1,102,55 installed
I have uploaded the tour for preview here:
http://www.360media.co.nz/virtual-tours/vuda/
Zip file for download available here:
http://www.360media.co.nz/virtual-tours/vuda/build.zip
Likes: 14 posts
by bdd » Tue Dec 06, 2011 9:26 am
Did you set the Global Security Settings of your flash player so that your tour is in a secured folder ?
http://www.autopano.net/wiki-en/action/view/Panotour_Pro_-_Prerequisites
jandunlop
by jandunlop » Wed Dec 07, 2011 9:57 am
bdd wrote:Hello,
Gérald, that fixed it - fantastic thanks a million :)
panomano
by panomano » Thu Dec 08, 2011 7:58 pm
I noticed that this happened to me for the first time in PTPv1.7 but only after I enabled the "Panotour Maps" feature. Previously I had no problem to preview my tour, once again only after I added the map did it crash. After I applied the fix above all is well.
ron
by Destiny » Fri Dec 09, 2011 10:53 am
Hi... I just opened ptp and it said there was an update so I installed it.. oh hum.. Its now stuffed... Not happy I feel like a good cry....
Destiny...:(
PS.. I have been told before that original software is not effected with trial or beta versions download.. This update is a trail beta which has over ridden my software.. I do not have a licence number.. I just have a folder named licence_29166 with three licence files in it.. If I try to open them they are some kind of code...
by Destiny » Fri Dec 09, 2011 11:12 am
Hi again.... My husband found the code so it is now registered.... but the interface windows are all over the place... I think I was told before to delete something.. but I do not know which files......
by Destiny » Fri Dec 09, 2011 11:24 am
Yay.. I fixed it... I must be getting smart... I found this .. http://www.kolor.com/forum/p90546-2011-11-05-11-57-39#p90546
I remember this before... but I did not do it since I was really worried about stuffing it up and I did not have the serial code.. but we found it so all good....
Destiny... :)
by Destiny » Sat Dec 10, 2011 1:26 am
Me again..... So far soooo good with ptp 1.7...its just great... I have always loved this software, its easy to use, and now even more clean and tidy... ptp 1.7 is the best of the best available in my view. Although I would still like to see more options with the thumbs and more features to make a more interesting tour... It's all about capturing the viewers imagination and holding their attention to keep them on your web site.... without making it tacky...
The mouse over button is nice and the light blue line to show the active area is very nice and clean. I would like to see more 'loading' options.. I would also like to be able to not only export the cube faces but the entire pano after the nadir has been fixed... I would also like to see more options for the thumbs such as my flash version would be good... My own swf thumbs never crashed so it does work... I will put it up again soon.... Now we are on Term break so no school I have time to play with thumb options...
by Destiny » Thu Dec 15, 2011 11:27 am
Hi.. I have just updated ptp... to 1.7.1.. it loaded fine and looking and working great..! Well done Gérald, those were major/important fixes you did there reading the fix log...
