Unable to export from PTP 1.6.1 on Lion
IgnacioFerrando
by IgnacioFerrando » Wed Oct 05, 2011 5:57 pm
I have a problem, when I can't export any tour from PTP 1.6.1 on Mac OS 10.7.1... when I make a project and try to generate it always I get un error with this message:
"Impossible de crer l'image partir du fichier:
/transparent.png"
and If I opt the project to my Mac Book Pro with the same system then I'm able to export it...
any ideas of what can I do??
thanks
ZITRONENWOLF
Re: Unable to export from PTP 1.6.1 on Lion
by ZITRONENWOLF » Fri Feb 28, 2014 10:26 pm
I have the same problem with PTP 1.8.0 and Lion OSX 10.7.5. I eventually upgraded to Lion and now I can't export projects in PTP although PTP 1.8.0 should be compatible even with Mountain Lion (OSX 10.8): http://www.kolor.com/blog-en/tag/mountain-lion/
Is it not compatible with Lion?
Is there a solution?
ZITRONENWOLF
by ZITRONENWOLF » Tue Mar 04, 2014 11:52 am
Hello, Help Desk answered and the solution is to go to the preferences and restore the settings.
by klausesser » Tue Mar 04, 2014 12:33 pm
IgnacioFerrando wrote:and If I opt the project to my Mac Book Pro with the same system then I'm able to export it...
Can you just export it or can you create/open it on the MacBook Pro?
by klausesser » Tue Mar 04, 2014 12:35 pm
ZITRONENWOLF wrote:I have the same problem with PTP 1.8.0 and Lion OSX 10.7.5. I eventually upgraded to Lion and now I can't export projects in PTP although PTP 1.8.0 should be compatible even with Mountain Lion (OSX 10.8): http://www.kolor.com/blog-en/tag/mountain-lion/
I use PTP 1.8 on a MacPro with 10.7.5 - no problem at all.
