Panotour Pro Mac - Map hotspots link incorrectlyuring hotspots that
Dizzy View
by Dizzy View » Mon Sep 12, 2011 7:37 am
I have created several virtual tours with maps featuring hotspots that link to other virtual tours. I published them as Flash, with XML data embeded and they all work fine. I gave them to the client who has linked them here: http://www.ssu.uts.edu.au/housing/residences/yuratour.html
I'm not sure how they have linked the tours but now the hotspots in the maps link to the wrong tours.
Any ideas why they are linking incorrectly? Is it their fault or my fault?
Any help would be greatly appreciated.
Thanks.
by mediavets » Mon Sep 12, 2011 9:46 am
Dizzy View wrote:I have created several virtual tours with maps featuring hotspots that link to other virtual tours. I published them as Flash, with XML data embeded and they all work fine. I gave them to the client who has linked them here: http://www.ssu.uts.edu.au/housing/residences/yuratour.html
Thanks.
Which of the many tours linked from that page shows the problem you describe?
I note that the fullscreens function won't work with the way they have linked the tours.
