Running a YouTube video in a Panotour Pro tour
MackyLuke
by MackyLuke » Mon Jun 13, 2011 11:02 pm
I need to run a YouTube video in a Panotour file. Is there any technical note on this one?
Luc
by mediavets » Mon Jun 13, 2011 11:20 pm
MackyLuke wrote:I need to run a YouTube video in a Panotour file. Is there any technical note on this one?
Luc
If you can download it and save it locally then you can use it like any other video in a krpano/Panotour tour.
But as far as I know there's no way to link and embed a video hosted on Youtube in a krpano/Panotour tour.
MackyLuke
by MackyLuke » Tue Jun 14, 2011 11:39 am
Thanks for your response. Somebody told me that it is possible so I will continue my investigation.
Regards
Luc
by mediavets » Tue Jun 14, 2011 12:34 pm
MackyLuke wrote:Thanks for your response. Somebody told me that it is possible so I will continue my investigation.
Regards
Luc
I think you would be most likely to get a definitive answer from the krpano fourm:
http://krpano.com/forum/wbb/index.php?l=2
If you find out please report back here so we'll all know the score.
MackyLuke
by MackyLuke » Tue Jun 14, 2011 1:03 pm
I just talked to someone at Kolor and as of today, I cannot do it usons Panotour Pro. And yes, you are right KRPano forum is the best place to ask or find the infos.
Thanks for your reply
Luc
by mediavets » Tue Jun 14, 2011 1:09 pm
MackyLuke wrote:I just talked to someone at Kolor and as of today, I cannot do it usons Panotour Pro. And yes, you are right KRPano forum is the best place to ask or find the infos.
Luc
Do let us know if you find out from the krpano forum that it can be done by handcoding the XML.
Good luck.
the707
by the707 » Mon Dec 05, 2011 10:38 pm
I don't pretend to know how they do it but it certainly can be done using the KR Pano technology. Here is an example of it here:
http://monsoon360.com/tours/tao_beach/tour.html
Click on the movie reel on the TV for an example. From the back end of this system I have an area that I simply pick the hex color for the background and paste the you tube embed code (iframe). This also quite handy for displaying a webpage within the tour.
Any chance we could get that functionality here from Panotour Pro? I would much rather use Kolor than this competitor.
GeoS
by GeoS » Wed Dec 07, 2011 1:27 am
I can confirm - it is possible to put YouTube video with YouTube player into the krPano/kolor panotour projects/kolor autopano projects:
http://redbull.fantag.eu/iframe.html
http://kk2.fantag.eu/
If anyone is interested then send me a PM or email me.
the707
by the707 » Wed Dec 07, 2011 9:35 pm
GeoS wrote:I can confirm - it is possible to put YouTube video with YouTube player into the krPano/kolor panotour projects/kolor autopano projects:
I emailed you, definitely interested! Thanks!
Fortran
by Fortran » Wed Jan 16, 2013 12:51 pm
Hi, just wondering, has anyone had any success in modifying the .xml to enable the embedding of YouTube videos?
GeoS
by GeoS » Wed Jan 16, 2013 11:27 pm
No, as you can't put static URL to video stream hosted on YouTube to your XML file. It's dynamic that is why you have to handle it in dynamic way.
by Destiny » Thu Jan 17, 2013 3:16 am
Hi...
The xml can be used for the call to trigger the hotspot.. Here are two examples of YouTube playing using two very different methods..
http://members.westnet.com.au/dps/js/content/virtualtour.html
Fortran wrote:Hi, just wondering, has anyone had any success in modifying the .xml to enable the embedding of YouTube videos?
