Sound on the Panorama with Panotour Pro
Acmj
by Acmj » Wed Dec 15, 2010 3:36 pm
I can not put sound on the panorama.I select the file and nothing happed.
Do I something wrong? or I have problem with my panotour pro?
On the project the sound is alright the problem is on the panorama sound
Can somebody help me?
thank you
by mediavets » Wed Dec 15, 2010 4:39 pm
Sound (MP3) attached to a pano image is working fine for me with PTP 1.5 RC2 on Windows XP/32.
Which version of Panotour Pro are you using and on which OS?
The latest release of Panotour Pro is V1.5 RC2:
http://www.autopano.net/forum/t10745-panotour-panotour-pro-v1.5-rc2
Acmj
by Acmj » Thu Dec 16, 2010 8:36 pm
I'm use Panotour Pro Beta 2.Thank you I will try the new one.
