Panotour Bug reporting readme
by AlexandreJ » Thu Nov 25, 2010 10:20 am
This is just a reminder on how to report efficiently some bug or issue you found in Panotour / Panotour Pro
Notations
Use the version inside bracket :
[Panotour 150 RC] Description as efficient as possible
[Panotour Pro 150 B2] Description as efficient as possible
If the platform you are using seems to be relevant, add the plateform ( Win32, Win64, mac10.5, 10.6, linux32, linux64 ).
We will post our comments inside the topic :
- confirmed, fixed, need some more description, share the panorama set to check it, etc.
- topic header will not be changed to prevent links from the wiki to broke, so get it straight the first time.
Note : Internally, we are using since a couple of month some standard bug reporting tool. We'll try to work with it on this forum too.
A new bug, not reported yet, will get an issue number and tracked by this number here.
For the moment, we don't put that bug reporting tool public because I'm not sure every reporter could use it in the right way that it should be.
Nevertheless, I really thing that once we are used to it, we'll probably put public that part too and you will have a formalized way to describe bug ( If you know bugzilla, it will be like this one. It's not, but it similar ).
vincen
Kolor Certified Trainer
Likes: 23 posts
Liked in: 4 posts
by vincen » Thu Nov 25, 2010 1:31 pm
AlexandreJ wrote:Nevertheless, I really thing that once we are used to it, we'll probably put public that part too and you will have a formalized way to describe bug ( If you know bugzilla, it will be like this one. It's not, but it similar ).
Good idea :) will help to follow more efficiently bugs and limit duplicates ;)
Vincèn
Blog: http://www.skivr.com
