[Panotour Pro 1.5 b2 WinXP/32]Sound file as the Display/Object error..
by mediavets » Sat Nov 13, 2010 1:25 am
If you specify a sound file as the Display/Object for Point hotspot you get an error message on playback.
ygilquin
by ygilquin » Mon Nov 15, 2010 4:56 pm
Thank you, this is nonsense to propose some sound file as display object of a spot.
Issue 419 open (will be fixed in release version).
Yann G.
www.kolor.com
by mediavets » Mon Nov 15, 2010 5:42 pm
ygilquin wrote:Thank you, this is nonsense to propose some sound file as display object of a spot.
It may be 'nonsense' in the sense that it was not your intention to allow this, on the other hand it would enable one to place directional sound.
But I agree that a better solution would be to offer a new audio hotspot type, as proposed here:
http://www.autopano.net/forum/t10133-sound-hotspots-for-directional-sound
