[Panotour Pro Beta2] [Win7 64bit] - Set as default buttons don't work
Motarny
by Motarny » Fri Nov 05, 2010 12:36 am
Clicking at icon for save as default in any tab don't work.
Settings are not remembered.
ygilquin
by ygilquin » Fri Nov 05, 2010 11:01 am
Some settings are not saved persistently. Could you please specify what settings you try to save ?
Also note that once saved, settings are applied to all new objects created, but not to those already present in the tour.
Yann G.
www.kolor.com
Liked in: 129 posts
by mediavets » Fri Nov 05, 2010 12:22 pm
ygilquin wrote:Some settings are not saved persistently. .
So do please tell use which are and which are not!
rbackhaus
by rbackhaus » Mon Nov 15, 2010 8:37 pm
yes please,...can we also a set these as permanant faults, or have a "select all panos" button, to set for ie like for FOV,..90 is too high,..
ygilquin
by ygilquin » Tue Nov 16, 2010 2:34 pm
"select all panos" is achievable easily through multiple selection with mouse in central view or Ctrl+A shortcut
Yann G.
www.kolor.com
