[Panotour Pro Beta2] [Win7 64bit] - Nadir scaling bug
Motarny
by Motarny » Fri Nov 05, 2010 12:34 am
1. Adding pano to Panotour Project
2. Setting file for nadir logo and scale for ex. 0,4 (default is 0,2)
3. Nadir logo is correctly scalled.
4. Adding next pano.
5. Setting file for nadir logo and scale for ex. 0,4 (default is 0,2)
6. Panotour don't scale logo. Default 0,2 remains.
I can set nadir scaling just for first pano in tour...
by mediavets » Fri Nov 05, 2010 1:04 am
Motarny wrote:1. Adding pano to Panotour Project
It seems to work OK for me with Panotour Pro 1.5 beta 2 and Windows XP/32.
I was able to set different scaling factors for two panos using the same nadir patch image.
ygilquin
by ygilquin » Fri Nov 05, 2010 10:51 am
Issue 408 open.
Yann G.
www.kolor.com
rbackhaus
by rbackhaus » Mon Nov 15, 2010 8:33 pm
re: 408 ,..for me upon first opening I can scale ONE nadir in a pano with the enter button. Then the enter button wont work for a second pano. If I save and reopen project then I can do it againg, but only ONCE.
rob
