[Panotour 1.5 beta2] Export/Import cube faces...
by mediavets » Sun Oct 31, 2010 11:03 am
Well....exporting and importing cube faces works in beta 2, BUT...
bizarrely on importing previously exported cube faces Panotour does not by default get the orinetation of the cube faces correct and you have to move/drag the zenith and nadir images to the right places by hand.
And even then the centrepoint of the equirectangular is different from that of the orginal image.
I'd expected exporting and then re-importing cube faces using default settings to result in a reassembled equirectangular image that was identical to the source image.
renan
by renan » Wed Nov 03, 2010 4:29 pm
We do not reproduce this.
It's like the last picture (nadir) is detected as the first one and all is circularly shifted.
May be something changed after having editing the nadir (if this is the case...).
Can you send us this sample :
http://www.autopano.net/forum/t766-ftp-server
by mediavets » Wed Nov 03, 2010 5:15 pm
renan wrote:We do not reproduce this.
Done - look out for cubefacetest.zip
renan
by renan » Fri Nov 05, 2010 4:27 pm
This is happen under XP but not under 7.
In XP the order of selection change the order of files.
The first picture must be selected in last to be the current one and finally the first one...
open issue 395
