little plant lag
asafmordechai
little plant lag
by asafmordechai » Sun Oct 24, 2010 7:23 am
i am using that fetcher in my tour.
when i am playing the tour i have a lag during the zoom in intro.
asafmordechai
by asafmordechai » Tue Oct 26, 2010 7:30 am
in the new beta the little plant introduction don't work at all.
renan
by renan » Tue Oct 26, 2010 8:12 am
I have not reproduce this. On which platform are you ?
by mediavets » Tue Oct 26, 2010 9:31 am
Little planet intro works for me on Windows XP/32.
asafmordechai
by asafmordechai » Tue Oct 26, 2010 7:44 pm
win 7 64bit
micha22
by micha22 » Tue Oct 26, 2010 9:09 pm
Me to, i use win 7 64 bit
best michael
renan
by renan » Wed Oct 27, 2010 7:32 am
Default time of little planet is 0... We will change that.
Can you confirm that is also your problem ?
zanya
by zanya » Mon Nov 01, 2010 6:27 pm
hello,
i have the same problem running mac osx 10.6.4 64bits : the little planet works only with the 2nd panoramas
by mediavets » Mon Nov 01, 2010 6:34 pm
zanya wrote:hello,
Do you have this tour on-line so we can see this bug?
zanya
by zanya » Tue Nov 02, 2010 12:21 am
i did a virtual tour and i got ridden of it... it looks very silly. try a virtual tour with 3 panoramas
panocanarias
by panocanarias » Tue Nov 02, 2010 3:46 am
asafmordechai wrote:in the new beta the little plant introduction don't work at all.
Making a quick "one pano" test, fooling around with the various "Project Properties" options, I noticed a problem with littleplanetintro, too.
But curious, sometimes littleplanetintro came up, working like expected; next time the intro was skipped, jumping directly to initial view.
The later always happend, when I selected a Control Template with "Rotation" (Navi+Rotation; fullscreen+Roatation; ..); but not Rotation only template..
I checked the xmls and noticed that both files (xxx.xml and xxx0.xml) come with an "onxmlcomplete=..." event.
Everytime both of the xml-files have their "own" "onxmlcomplete=... event, even when the commands differ, the littleplanetintro is skipped.
If you combine both commands in just one line, so that there is only one onxmlcomplete event, everything works fine.
I do not know much of xml programming; but may these (buggy ?) controls-templates cause the problems?
Salu2, Klaus
by mediavets » Tue Nov 02, 2010 4:17 pm
Salu2, Klaus
Welcome to the forum...
Yes, well spotted, there doe appear to be something wrong with the Little planet intro when combined with certain Template options.
My comments:
1. I found that whenever I chose to use the Little planet intro - regardless of which Template I chose or none - then when the tour loads in the browser there always a 'brief flash' of other panos in the tour before the first designated pano appears.
2. Results of tests with Little planet intro selected and different Templates - see 1.
None - little planet intro works.
Navigation - little planet intro works.
Navigation + Help - little planet intro works.
Fullscreen navigation - little planet intro works.
Fullscreen navigation + Help - little planet intro works.
Navigation + Rotation - little planet intro does not work.
Navigation + Rotation + Help - little planet intro does not work.
Fullscreen navigation + Rotation - little planet intro does not work.
Fullscreen navigation + Rotation + Help - little planet intro does not work.
Rotation - little planet intro does work.
Rotation + Help - little planet intro does work.
zanya
by zanya » Sat Nov 13, 2010 7:47 pm
i did one virtual tour with an intro with 0 sec long and little intro 4 secs long. It's working with fullscreen navigation.
But i have a flash of the liitle planet just before my intro pictures appeared.
Once the little planet is done. I have my intro picture on screen. I just click on it and it's gone. It's very convenient.
