The colors change on having personalized the splash screen?
f7
by f7 » Fri Oct 08, 2010 8:34 pm
The colors change on having personalized the splash screen??????
Botton is diferent!!!!!
renan
by renan » Mon Oct 11, 2010 11:19 am
Template resources are colorized but not user resources...
You can add your splash screen in the template resource and it will be colorize too.
Open the template directory via the edit menu.
Open the "theme" directory.
Open the xml file of the theme (2D.xml for your sample)
Find where are listed all helpscreen (for exemple : <helpscreen file="img_help_en.png" caption="info_nav_en" lang="en"/>)
Add you own help screen line and your own picture in the graphics directory.
f7
by f7 » Tue Oct 12, 2010 2:59 pm
Thank you very much, Renan
Now if I understand it, there was only changed by it. PNG and have no clear order in XML,
I thank intrentarlo
Greetings
