[Panotour Pro 1.5 beta 1] Export Cube faces
by gkaefer » Sat Sep 25, 2010 2:41 pm
if I do "file"->"Export"->"Export Cube faces" and here:
open a 6GB .kro non 360x180 panormao
and use as filename default %n_%f.tiff and also tested with %n_%f
than export success rate cam up to the point shown in screenshot and after some seconds later window closes without error message and without any file exported in the given folder.
PS: no dodumentation about used output file.... Can I say %n_%f.jpg and jpg will be produced or %n_%f.kro and a kro cube face will be the result?
Liebe Gruesse,
renan
by renan » Wed Sep 29, 2010 8:20 am
We have to improve this UI.
We use the extension of the file name to know the output format.
by mediavets » Wed Sep 29, 2010 9:06 am
renan wrote:We have to improve this UI.
I do hope so.
This seems inconsistent - everywhere else in the program in similar circumstances you offer a drop down to determine filetype, so why not here?
renan
by renan » Wed Sep 29, 2010 9:17 am
It's planned in the UI improvement.
