[Panotour Pro 1.5 b1 WinXP/32] Map feature misbehaving
by mediavets » Fri Sep 24, 2010 4:37 pm
I seem to have run into a bug in the map plug-in feature.
Here's a sequence of screenshots to illustrate the bug.
Screenshot 1 - shows how I configured the map image - Yes, I know it's not a map but that's not the point.
Screenshot 2 - shows the appearance of the map image on first loading the tour; the dimensions are odd.
Screenshot 3 - shows the map image after clicking on it to show at specified size.
Screenshot 4 - shows the map image after clicking on it again to reduce its size - now it is displayed as I would have expected it to display when tour was initially loaded.
micha22
by micha22 » Mon Oct 18, 2010 11:03 pm
i´ve had the same problem and now i have the answer :D
I copy the xml from autopano tour beta 11 and paste it in the xml of panotour pro.
Here it is
<plugin name="map" url="Hohentwieldata/map/map.png" keep="true" align="lefttop" x="10" y="10" width="800" height="prop" handcursor="false" onloaded="set(plugin[map].width,80);action(hidemapspot);" onclick="action(openmap);"/>
Url: your picture
width and height: what you prefer
Here you can make the settings of the size when the map is closed
<action name="closemap">
set(plugin[map].onclick,action(openmap););
tween(plugin[map].width,100);
tween(plugin[map].height,80);
</action>
Try it out.
Best michael
renan
by renan » Tue Oct 19, 2010 10:34 am
issue 345 open
micha22
by micha22 » Tue Oct 19, 2010 12:36 pm
issue 345 open :|
What does this mean ?
Best michael
by gkaefer » Fri Oct 22, 2010 12:15 pm
micha22 wrote:issue 345 open :|
Best michael
with next available beta this issue should be fixed.
micha22
by micha22 » Fri Oct 22, 2010 7:15 pm
Thank´s Georg :)
by mediavets » Tue Oct 26, 2010 9:33 am
It is fixed in Panotour 1.5 beta2.
