Error: Panotour trial version   [SOLVED] - View the solution
vicliciouss
by vicliciouss » Fri Jan 22, 2016 2:49 am
I'm not sure why i'm getting the Error: Panotour trial version when upload the tour to the hosting. You can view the tour here: uyenstudio.com/360demo/virtualtour.html
Screenshot: http://screencast.com/t/oRto1eUP
The tour displaying well when i open on the browser offline.
Please advice.
Re: Error: Panotour trial version  [SOLVED]
by Annis » Fri Jan 22, 2016 10:21 am
Are you using version 1.8?
Do you have a licence? Are you registered?
With the trial version of Panotour 1.8 you can not upload the tour, that was one of the demo limitations.
vicliciouss
by vicliciouss » Fri Jan 22, 2016 2:40 pm
Yes, of course i have registration code.
Screenshot: https://goo.gl/xe3f6S
by Annis » Fri Jan 22, 2016 3:10 pm
Did you edit the splashscreen in the screenshot? it doesn't look edited.
If it were registered then it would show a licence, like so:
That is not your case, nor does it look to be in trial mode.
Could you tell me where you downloaded the version you are using from?
vicliciouss
by vicliciouss » Fri Jan 29, 2016 9:27 am
Hi Annis,
I'm not sure where the error come from but i have bought the 2.5 version already. Thank you for your support.
