Panotour 1.8 to Panotour 2.3   [SOLVED] - View the solution
geas35
by geas35 » Thu Oct 29, 2015 6:33 pm
I have my site of tours 360, all made on Panotour 1.8, and it doesn´t works on Android Devices.
Now i have the Panotour 2.3.
I need to know if I will have to export all the old tours in the panotour 2.3, to be seen on Android devices.
thank you
Re: Panotour 1.8 to Panotour 2.3  [SOLVED]
by mediavets » Thu Oct 29, 2015 6:38 pm
Yes you will have to rebuild your tours using 2.x for them to be viewable on Android platforms.
You can open .kpt files created with 1.8 in 2.x but most features will be lost.
You may wish to installed 2.5 beta 4.
geas35 likes this post.
geas35
by geas35 » Thu Oct 29, 2015 7:13 pm
Many Thanks for the answer!!
