Ponotour Pro 1.8 HTML5 output (for mobile devices)   [SOLVED] - View the solution
alfatv
by alfatv » Wed Sep 23, 2015 1:18 pm
We have purchuased Panotour Pro 1.8 and we are interested in using HTML5 technology instead of Flash. In help included to Panotour Pro 1.8 application producer included information that there is a tick that enables compatibility with iPhone and iPad and saves output in HTML5 technology. We are not able to use that function.
I would like to inquire if there is a possiblity for saving HTML5 output in Panotour Pro v. 1.8.
Kind regards
Re: Ponotour Pro 1.8 HTML5 output (for mobile devices)  [SOLVED]
by Annis » Wed Sep 23, 2015 1:57 pm
Version 1.8 doesn't output HTML5. It outputs a twitched and tweaked version of the tour that barely makes it function on iDevices, which is pretty limited.
If you want HTML5, you need vesion 2+.
