update to krpano 1.17 possible?   [SOLVED] - View the solution
kosmomedia2004
by kosmomedia2004 » Wed May 21, 2014 8:02 am
I have Panotour Pro 1.8 and I want to use New: krpano 1.17. What do I have to do? Is it possible? Because I know that in the past it was possible to update the created Panotour Pro file...
Thanks for your help!
Liked in: 14 posts
Re: update to krpano 1.17 possible?
by gkaefer » Wed May 21, 2014 5:49 pm
kosmomedia2004 wrote:I have Panotour Pro 1.8 and I want to use New: krpano 1.17. What do I have to do? Is it possible? Because I know that in the past it was possible to update the created Panotour Pro file...
you have to upgrade to panotour pro 2.x license. You can do it from Insider your useracount here (link right):
http://www.kolor.com/updates.html#panotour-pro
panotour 1.8 cant handle Features from krpan 1.17
ptp 2.x Comes with krpano 1.17 license embedded. you can use krpano 1.17 Features via ptp 2.x gui and exported XML files can be enhanced with krpano 1.17 Features manually too....
PS detailed differenced betwen both krpano Version: http://krpano.com/forum/wbb/index.php?p ... #post52867
kosmomedia2004
by kosmomedia2004 » Wed May 21, 2014 8:16 pm
At the moment I don´t want to update, it´s too expensive for me. In the krpanotools there is an update tool...what is this for?
Thanks!
Re: update to krpano 1.17 possible?  [SOLVED]
by mediavets » Wed May 21, 2014 8:52 pm
kosmomedia2004 wrote:At the moment I don´t want to update, it´s too expensive for me. In the krpanotools there is an update tool...what is this for?
Thanks!
See this thread:
viewtopic.php?f=33&t=22051&hilit=krpano+update+tool
